NDI
NDI spark input great on one pc Laggy on 2nd
Joined: 4/29/2018(UTC) Posts: 2 Location: Vancouver wa
Kind of weird problem. I have vmix on a desktop with a i5 processor and 16 gig ram and everything is working properly. I have a much higher powered laptop with a i7 64gig ram and a quadro k1100 graphics cardthat works great with all other stuff on vmix. But when I add may NDI NewTek spark it is very laggy. My PTZ optics camera has the same problem over NDI but not usb. I would think it was the network but it works on my lower PC just fine. And in the NewTek monitor app it looks perfect no lag.
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
You did not mention the most important things when it comes to NDI : network config ! Are you using the Spark wirelessly? What is your network speed ? and so on...
Good point. I’m using a netgear pro series unmanaged gigabyte switch with snooping and multicast. Everything is over Ethernet with cat 6 cables. Do you need more info
Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
Jonathan F wrote:I have a much higher powered laptop with a i7 64gig ram and a quadro k1100 graphics card... It may be more powerful, overall, but what if the NDI|HX decoding is done by a single CPU core? How does the clock speed differ between the desktop i5 CPU and the mobile i7? An i3 with a fast clock speed can sometimes outperform an i7 on single-threaded tasks, given that CPUs with fewer cores often have higher clock speeds than CPUs of a similar series that have more cores on the die. Just a thought.
Jonathan F wrote:Good point. I’m using a netgear pro series unmanaged gigabyte switch with snooping and multicast. Everything is over Ethernet with cat 6 cables. Do you need more info Maybe a typo, the switch is unmanaged but offers features like IGMP snooping? Sounds like a managed switch. If it is working in NDI Studio Monitor on this system, but not in another application it sounds like the Spark and network are correct, and you are running into an application issue. Are you running latest version of vMix? NDI|HX can take advantage of GPU hardware accelerated decoding, perhaps make sure you GPU drivers are up to date? Does the laptop offer switchable GPU support? If so, makes sure the application is using the better GPU. Kane Peterson NewTek
NDI
