NDI
NDI app freeze frame stutter but Connect spark works
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
using the ndi mobile app the picture just jogged along but with connect spark it was fine.
instantly i though the project is 25fps and the app is 30fps - but it works fine at home on a home hub but then not on location with 1400mb wifi
any idea what might be affecting this, it's just on location with the app but the WiFi works fine for other devices and cameras,
thank you
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
1400 wifi means nothing. the total throughput of an access point is never what you get just use cables
Full bandwidth NDI isn't designed for WiFi usage, connect using gigabit wiring. NDI-HX is designed to work on WiFi.
Kane Peterson NewTek
NDI
