Rinsky
#1 Posted : Wednesday, April 18, 2018 12:45:03 PM(UTC)
Rinsky
I have to (i guess relatively simple?) feature requests regarding the UI:
1. Please make it possible to go to the next or select the inputs you want to edit, while in the input options panel. Maybe a list on the right hand side that let's you scroll through all inputs. It would make it easier to make changes on inputs, without going back to the main UI and searching for the input.
2. make the audio meter tab also dockable to the bottom of the screen. So all inputs would be above it and you could always have an eye on the audio meters and correct it without searching through them too long. (will post a picture to show what I mean)
