wtm
#1 Posted : Wednesday, April 11, 2018 3:29:45 PM(UTC)
wtm
From a week to now, we are not able to select groups in the "location" option of VMix. Only events and pages are appearing.
Has there been any change to this broadcast format?
Thank you!
NHT
#2 Posted : Wednesday, April 11, 2018 5:11:47 PM(UTC)
NHT
Have they changed it so that you have to be group admin?
rudyengels
#3 Posted : Friday, April 13, 2018 10:39:57 AM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
Did you try this?
1. Go to https://www.facebook.com/live/create
2. Click Create Live Stream
3. Choose where you want to post your live broadcast (right hand side)
4. Select Enable persistent stream key if you want your stream key to be permanent. If this isn't selected, you won't be able to use this stream key again after the stream ends
5. Copy and paste the server URL and stream key or pesistent stream key into the settings of your streaming software and start the video stream from your encoder. A preview screen will appear
6. Write a description, Title and Video Game tag
7. Click Go Live or Schedule
mgrayeb
#4 Posted : Sunday, April 15, 2018 6:36:54 PM(UTC)
mgrayeb
I too am finding that when I select the Facebook API stream option after logging in that I can only choose from Pages or Events -- none of the groups for which I am an administrator are listed.
BentRS
#5 Posted : Wednesday, May 2, 2018 12:25:34 PM(UTC)
BentRS
This option is working again now....
thanks 1 user thanked BentRS for this useful post.
mgrayeb on 5/2/2018(UTC)
