how change imput play end video
How to change automatically input play end video ?
Best regard, Phab
My english is very bad ;)
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Thanks doggy, But I do not understand triggers, could someone from the forum explain to me the triggers?
Best regard, Phab
je suppose en francais de preferece , la miene n'est pas asser bon petit effort: des declancheurs, dans votre cas qui declanche une function (Oncompletion) aux fin du video (fade to votre selection par example) ? doggy attached the following image(s):  trigger.JPG (45kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
Great, un grand merci à doggy et zenvideo !
