Joined: 11/9/2017(UTC) Posts: 9 Location: Resistencia
Hi. As Blackmagic Decklink Duo 2 is a card whose SDI connectors can be used as video input or output, I ask: How should I configure the camera capture when adding inputs to the Vmix with the configuration of each SDI connector in the "connector mapping" option of the program? Desktop Video Setup of the Blackmagic Decklink Duo 2 card, for 2 inputs and 2 outputs, 3 inputs and 1 output or 4 inputs and 0 outputs? Thank you.
