You have been a member since:: 8/5/2017(UTC) Posts: 135 Location: UK
Thanks: 15 times Was thanked: 11 time(s) in 9 post(s)
Hi There, I run a weekly show with up to 3 vmixcall guests which works great. I have my mic going into a mixer and then into a capture input, I do not monitor this via the vmix headphone mix due to latency in the audio, I monitor it directly from the mixer and monitor the vmix calls via the audio output of the audio device from the mixer.
I am trying to set up a bus A private audio channel, eg, I remove all sources from Master bus, and into Bus B so we can talk without going to air However, if I do this how to the guests hear me if I don't have my channel monitored via the headphone level in the Vmix mixer channel? As monitoring myself reintroduces the through latency. It seems that the mix minus only works on vmix calls, not my physical input?
Nick
