BETech
#1 Posted : Thursday, March 15, 2018 8:06:10 PM(UTC)
BETech
With the release of our latest IBM security update on March 15th, we will no longer be supporting encoders that use the TLS 1.1 or lower for authentication via Ustream login.
You can read more about this security update here https://support.ustream....b967eb52a25d6aafef68dd53
These encoders include:
Ustream Producer 7.0 and older (PC)
Producer 7.0.1 and older (Mac)
Wirecast 7.0.1
vMix below ver. 20.0.0.51 (PC)
If you are using one of these encoders, we recommend you upgrade to Wirecast 8.3, vMix 20.0.0.55 or OBS as these are unaffected.
You can also use the RTMP URL and streamkey found inside your dashboard to connect as RTMP type of connections are unaffected by this update.
We apologize for the inconvenience.
IBM Cloud Video
thanks 2 users thanked BETech for this useful post.
richardgatarski on 3/16/2018(UTC), rowby on 3/20/2018(UTC)
