giltender
#1 Posted : Thursday, March 8, 2018 11:32:36 PM(UTC)
giltender
I have a video clip that is two hours long and need to be able to precisely navigate to different sections of the video clip. The position control is only allowing me to skip in 30 sec increments. Is there a way to assign a keyboard shortcut to skip forward or backwards (5 or 10 sec)?
DYosua
#2 Posted : Friday, March 9, 2018 12:44:33 AM(UTC)
DYosua
Was thanked: 15 time(s) in 12 post(s)
You can use the "SetPosition" shortcut with the Input set to your clip. For the value, you can use "+=5000" (without the quotes) to skip ahead 5 seconds. To skip backwards, you can use "-=5000". The value is in milliseconds, so ten seconds would be 10000.
Guest (4)
