question about titles and lower 3rds (in terms of best setup/practices)
Thanks: 12 times Was thanked: 3 time(s) in 3 post(s)
So - we have a situation here were there are multiple lower thirds / multiple texts.
What I mean by that is
Not just 4-5 guests, each with a lower 3rd /name etc. (it's a custom graphic w a separate text title)
But also variants on those lower 3rd graphics. So that the image behind changes every so often.
I am trying to wrap my head around the best way to do this.
I am coming from xSplit - on xsplit - you would click a scene - and see all the elements on that screen. I would have all the lower third images loaded into that scene - and could just tick on and off the ones I wanted displayed in real time.
w vMix - at least if I am doing this right - I have all the images loaded in the main assets folder. I have a multiview input w the camera and all the lower thirds.... When I bring that input into preview. I then click the cog, click the multiview, and uncheck the one I don't want to display anymore, then push it live.
Is there an easier/faster way to do this?
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
you do realize that a title can have variable text and image? So one template can cater for different looks/data Datasources should solve your problem containing the guests name and link to its image and bind those to your title. couple of hrs ago : https://forums.vmix.com/default....ts&m=51261#post51261
I appreciate the reply -
But -
I am VERY new to vMix - - just telling me data sources will solve this problem - doesn't help sadly.
I am somewhat familiar w data sources... but I can't wrap my head around how that solves the problem.
i am more of a visual person and can only asume what you want it to look like from text but titles have variable fields for which the content can be changed manually or from a (datasource) list or by external commands even. as an example say you have chooses the included NewsHD2.xaml title and you rightclick on this input you will be able to change the text it contains (Headline and Descrition for example) but you can also change the background image there. This is the basic manual way you can add various texts and image selections prepared in the box below those and create a little list of presets to select later you can do the same with a datasource list containing like all your names and references to the images you want associated with or even have 2 datasource lists ; one for your names and a seperate one for your graphics references (they will have to be links to their locations) to select from and associate the title fields to the appropriate data source item when familiar with the process of changing and showing/hiding the title overlays one can design a appropriate title with the title designer for your specific purpose check out some of the outstanding video tutorials here : https://www.youtube.com/channel/UCIb-SjM3xvelTsQ9VTwIeKg
@ iamralphsutton Depending on the complexity of your set-up, the simplest and quickest solution in my books is to create multiple MultiView Inputs (same camera/graphic different text/graphic) and just switch between and among them (or even auto switch with the PlayList) thus not having to click through menus and tic boxes. Alternatively, although a more involved and advanced process, is to use DataSources as doggy mentions and/or Shortcuts, even the UTC by elgaf, for a more streamlined approach, but it will require some time to learn and get your head around. Ice
