Bryanne
#1 Posted : Sunday, February 11, 2018 5:40:25 PM(UTC)
Bryanne
Hi all. We are wanting to use Vmix for the purposes of chroma keying the background of the presenter.
I have asked Vmix about whether webinar applications can generally work with Vmix and they advised me as follows:
The main thing to look for is if the webinar program supports adding virtual camera inputs. In Vmix you can activate external output so the video output can be input into third party programs (such as Skype etc for example). The camera source will show up as 'vMix Video' if it supports virtual cameras.
Some flash based webinar services, don't support virtual cameras.
Can anyone advise what Webinar systems they are familiar with that support "Virtual camera input"
Many thanks
pop
#2 Posted : Wednesday, February 14, 2018 4:30:55 PM(UTC)
pop
Was thanked: 7 time(s) in 5 post(s)
I use vmix together with Bluejeans.com regularly (as a virtual webcam). Very stable. But for some reason I have to route the audio through virtual audio cable. It doesn´t work directly from vmix.
thanks 1 user thanked pop for this useful post.
Bryanne on 2/14/2018(UTC)
Bryanne
#3 Posted : Wednesday, February 14, 2018 10:51:33 PM(UTC)
Bryanne
Thanks Pop for your comment. I really need to use WMIX for webinars so that I can chroma key the background. Have you heard of anyone using it for this purpose?
