Desktop Capturing - two desktops or two or more windows
Joined: 8/31/2013(UTC) Posts: 11  Location: Bielsko-Biała, POLAND Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
Hi!
Maybe it's possible in 10.0.0.59, but I can't. Is it possible to capture from one computer two differents windows?
David
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
Hi David,
It is possible, you will just need to capture an area big enough to cover both windows. Then, create create two blank colour inputs which you can bring in the desktop capture via MultiView on each and move and zoom the input to cover the first and second windows.
Martin vMix
Hi Martin!
Yes, I know. I write this solution on the forum. I was thinking about simpler solution. :)
David
