NDI
Looking for Beta Testers
Joined: 2/7/2018(UTC) Posts: 45 Location: Saint Louis
Thanks: 4 times Was thanked: 4 time(s) in 3 post(s)
Hi All,
I have a graphics package that is ready for testing in the wild. It is a live paint and animation that supports NDI output up to 4k and can also save stills or file sequences (ok, it does avi and mov too but not well... yet)
Anyway, if you make, or ever wanted to make graphics but found the other apps too hard to setup or use.. this may be your bird.
I'm looking for 10 people do share this with right now. Message me if you have time. Ideally at least half of the testers will have some experience in any of the following apps (windows paint, fusion, after effects, newblueFx, livetext etc.)
Thanks, Mike Benke Benke Services/GlobalStreams
Joined: 5/13/2014(UTC) Posts: 521   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
Yes, that is it.. That pic of the UI is last revision though.... not drastically different, just a little freshened up.
This is a good opportunity to ask for specs of your windows machines that you would be installing on.
Things I'd like to know are:
Processor ram desktop resolution SSD or not GPU NIC or Wireless (for NDI)
This beta test is already working! I just built a layout file for 1600x900 resolution and am now working on 780x550 for a "windowed" version so you can see the desktop while running the app on a small laptop...
Happy to be involved. Have a number of systems/configurations I can test on for. Send me a PM here if you want the help.
I would like to play with this also :)
Processor Intel i5 Ram: 16GB Desktop Resolution: 1440p SSD HD: Yes GPU: Yes NIC for NDI
New Installer posted. Use the same link and go get it!
New Layouts, New Look!
Thanks for your help so far!
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Interested in testing product, please PM info.
Processor: Core I7-4770K ram: 32 Gb desktop resolution: Dual 1920x1080 and dual 1680 x 1050 SSD or not: SSD GPU: GTX750Ti NIC or Wireless (for NDI) Dual NIC and Wireless
Thanks: 12 times Was thanked: 1 time(s) in 1 post(s)
I would try it out. ASUS ROG G752VT
Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Processor: Core I7-6700K ram: 16Gb desktop resolution: 1920x1080 SSD : 512 SSD GPU: GTX690 NIC/Wireless (for NDI)
You have been a member since:: 2/9/2013(UTC) Posts: 264 Location: Katy, Texas
I would like to be a beta tester.
Processor: i7-6700HQ Processor 2.6GHz (Laptop) ram: 32GB DDR4 desktop resolution: 1920x1080 SSD or not: 256GB SSD for system and 525GB SSD for files GPU: GTX 1060 NDI: wired ethernet
Where is the download link?
Kelvin
Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
I would like to be a tester.
Processor: Intel i7 - 3770 Laptop Ram: 16 GB Desktop Resolution: 2X 1920x1080 SSD: Yes GPU: GTX 1050 NDI: Wired + Wireless
Angelo.
Can i download for test?
Sorry, didn’t mean to make that link public... if you downloaded in the last couple of hours and want to be a beta tester , please let me know and please don’t distribute. Thanks! Mike
New Build up. Same link
Add's more layout options in the start menu. (in case you see grey when opening app)
More NDI by the end of the week.. (input and multi-out support)
Your feedback is making the app better! Don't hold back.
New Forum is up for getting involved and answering questions about Panamation NDI. Again, this tool is for those who wish to create or modify their own graphics either live or pre-production to be brought into vMix or any other platform.
I would like to be part of the testing team
Processor: Intel i7 - 3770 Ram: 12 GB Desktop Resolution: 2X 1920x1080 SSD: Yes GPU: GTX 1050 NDI: Wired + Wireless
Where is the forum located Mike? I went to the link in the second post, and then to support/forums, but it took me to archived forums, and did not give me an option to register.
www.panamndi.com is the forum for beta testers (or any one else I suppose) to view tutorials, and see updates and information regarding how to install, known issues, etc. etc.
Hey Beta! New Upload with support for NDI Input. Draw over video! Do it in style! [img][/img] MikeBenke attached the following image(s):  panam pantone copy.jpg (1,031kb) downloaded 35 time(s).You cannot view/download attachments. Try to login or register.
 1 user thanked MikeBenke for this useful post.
Kewl! Looks like I'm at a point on my new system, I'll be able to reload this on that system, and start playing again!
Beta Testers, a new version will be posted tomorrow night. Improvements are:
- Faster frame rate for NDI input when drawing in telestrator mode. - Discreet NDI output option for each layer (up to 99). - General bug fixes
Regarding content, I am thinking of splitting that into a separate installer to keep the app installer size down (under 20 mb vs. 200 mb and growing)
Thoughts? Feelings? Any particular content you'd like to see added? Emoji's? More lower animated thirds?
NDI
