Feature Requests
Deselect All when opening/adding a Preset
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
Since there is no easy way to copy Input settings I increasingly re-use Inputs from other Presets by appending a few of the Inputs that I need. Since all existing Inputs are selected by default, it would be nice if there was way to deselect all - and then select the ones one need. Especially when the imported Preset contains a lot of Inputs.
(I now creating a Virtual Input is kind of a workaround. But besides the annoying "inheritance" of Virtual, it only works if the Input already exists in the current Preset).
Thanks.
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
Feature Requests
