Problem with audio sample rate
Thanks: 8 times Was thanked: 12 time(s) in 9 post(s)
I have some issues with sending audio out to a Sound Devices Mixpre-6 USB interface. I want to send a separate mix(A) to the headphones output on the Mixpre, but for some reason the interface switches to 44.1 KHz when I start up vMix. As far as I can hear it receives a 48 KHz signal, as the audio from the Mixpre is pitched and skipping.
The same happens if I set the Mixpre as the master out for vMix.
I play some audio from e.g. Chrome and the Mixpre is locked at 48 KHz, but as soon as I load my project in vMix it switches to 44.1 KHz.
Advanced Audio Settings is set to 48 KHz, and so is the windows settings.
Anyone have an idea?
Audio sounds fine through built in audio output.
