Frank@vancast.net
#1 Posted : Tuesday, January 30, 2018 10:05:40 AM(UTC)
Frank@vancast.net
Problem:
Can't hear the VMIX master output via headphones or speakers. (Other software works fine)
The master output is streaming and recording correctly
VMIX Configuration:
Both master output and headphones are matched to Default Windows Playback Device
Audio Advanced settings are:
Master Sample rate 48000
Master bit rate 16 bit PCM
Recording Audio: vMix Audio
Format: 48000Hz 16 bit 2 Channels
Windows Audio mixer:
VMIX appears within the applications and is enabled
Computer: brand new ASUS GL702V
vMix version 20.0.0.51x 64
I've spent about one hour searching the forum for a solution to this. Also compared the audio configurations with several other VMIX computers that I have.
I've been a VMIX user for several years now.
Thanks in advance for any help on this
Frank@vancast.net attached the following image(s):
Barney Box Lane
#2 Posted : Tuesday, January 30, 2018 11:22:52 AM(UTC)
Barney Box Lane
Have you got 'S' SOLO enabled on one of you're channels in the audio mixer, this would cause this if its been clicked and forgotten about
Frank@vancast.net
#3 Posted : Tuesday, January 30, 2018 11:37:24 AM(UTC)
Frank@vancast.net
Nope, as you can see in the attached screenshot no 'S' is marked.
Thank you anyway!
ovinas
#4 Posted : Tuesday, January 30, 2018 2:41:59 PM(UTC)
ovinas
Why are you routing the vMix outputs for Master and Headphones to the same physical output? How do you connect your Speakers and Headphones at the same time to one physical output? What is your "Default Windows Playback Device" and are your Speakers or Headphones connected to this device? Please check in Windows Sound Manager.
