Hi all, new kid on the block here :). I am an amature en audio/video enthusiast. I recently found a solution for creating dynamic mp3 playlists, based on rules. Beats creating music playlists by hand, and use them in a radio software (RadioDJ) as my personal jukebox. This way I can listen my music on any device both at home and away (online).
I also have a Home Theatre Media Server (Plex) that handles my video files and streams to anything you throw media at. Including my radio channel.
I want to do the same with my music videos. The first challenge is how to create dynamic playlists as I do for my mp3 files. MP3 files have heaps of media tags that I can use to filter from. Video files are more difficult the handle and to get the same efficiency. And for my use (you could call it a 24/7 non-stop music channel) I see no point in creating manual playlists.
This got me thinking... My on-the-fly generated mp3 playlists are stored in mySQL. If I could run a procedure that imports the current mp3 playlist, replace the text ".mp3" with ".mp4" I should be able to produce a playlist based on the rules in my radio software.
How does vMix handle working with mySQL databases? Are there other solutions out there that could generate rule-based dynamic video playlists?
Did some more research, and looking at it from a different angle. An alternative could be to load a pre-build m3u file. The challenge here is that an external script will be updating the m3u file every "x" minutes. Is there a way to automatically reload the m3u file in vMix every "x" minutes ?
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
You can load a folder/files into playlist in VLC and then save playlist file as M3U or M3U8. Then add playlist input to vMix that points to your newly created playlist from VLC.
@desmar: thank you for the suggestion. It is the last part I want to automate. In my radio software I can f.ex. create an event that every hour clears the playlist loads a new one and then starts playing. Can I do this in vMix?
connect to the mysql database and generate output as XML via PHP for example then you can load the xml data into Vmix Datasources
@corporatejames: Thank you for the suggestion. I know my options for exporting. My question is more tuned towards how to autoload a new imported playlist every few minutes.
