stevespaw
#1 Posted : Friday, January 26, 2018 2:57:31 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Hello Martin,
Could we get some info on how the new NDI 3 supports multicast in vMix?
We have several vMix systems that share NDI signals. Is this now multicast by itself ? How do we turn this on?
Thanks,
Steve
mavik
#2 Posted : Tuesday, February 6, 2018 3:53:01 AM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
Generally saying: Multicast has to be enabled at the NDI source and at the Switches inbetween. On the Switches make sure you use managed Switches and enable the IGMP Spoofing. On the receiving side the IP changes to one of the multicast space addresses. Multicast works like a RSS feed. You have to subscribe and then you are able to receive the data.
If your network doesn't support multicast stay with unicast and monitor for congestions.
stevespaw
#3 Posted : Tuesday, February 6, 2018 11:27:23 AM(UTC)
stevespaw
Mavik,
I am very aware of how multicast works.
My question is about NDI/vMix's implementation of it.
Specifically, are the outputs multicast enabled?
Also the receivers? I have had some issues when I have tried to turn on multicast with the NewTek PTZ's and getting vMix to see them.
Steve
kane
#4 Posted : Tuesday, February 6, 2018 3:25:30 PM(UTC)
kane
stevespaw wrote:
Mavik,
Steve
Install NDI Tools on the system and using NDI Access Manager you will have the ability to setup the multicast network. Make sure you run NDI Access Manager as Administrator for the changes to take affect. If you have a old download of NDI Tools, download it again to get the new versions of these tools.
Also, make sure your switches have IGMP Snooping enabled. If your switches do not have this feature, then you should not use multicast.
Kane Peterson
NewTek
stevespaw
#5 Posted : Tuesday, February 6, 2018 3:54:11 PM(UTC)
stevespaw
Kane Peterson
NewTek
Thanks Kane, I will look into this, So the Multicast is handled by the access manager, not the transmitters and receivers themselves?
I have not looked at the new access manager.
Steve
kane
#6 Posted : Friday, February 9, 2018 6:07:47 PM(UTC)
kane
Steve
Access Manager configures the registry settings that tells all NDI applications on this computer that they can use multicast.
Similar Topics
Curious behavior noticed when bridging SRT to UDP/RTP multicast (SRT)
by Archer01 11/13/2025 9:53:41 PM(UTC)
MULTICAST: A bad receiver's influencing the others (Windows as sender) (NDI)
by majorsky 4/16/2024 7:39:53 AM(UTC)
How Can I Tell vMix to Use Multicast on a Camera Input (General Discussion)
by kismetgerald 3/3/2023 12:29:28 AM(UTC)
MULTICAST STREAM IN VMIX (General Discussion)
by aijaz 2/26/2022 12:19:43 AM(UTC)
Can Vmix decode multiple PIDs from a multicast UDP stream ? (General Discussion)
by albaba.alnaser 4/12/2020 9:54:51 PM(UTC)
Broadcast UDP multicast output (Feature Requests)
by stevespaw 12/22/2019 2:10:42 AM(UTC)
NDI Multicast support (Feature Requests)
by stevespaw 12/7/2018 11:30:57 PM(UTC)
vMix NDI output and Multicast (NDI)
by Non Grata 12/6/2018 2:48:32 AM(UTC)
UDP multicast transport stream multiple audio PIDs (General Discussion)
by tzetze 8/21/2018 5:41:36 AM(UTC)
NDI Multicast for Venue displays (NDI)
by lael 8/17/2018 5:02:34 AM(UTC)
rtsp stream (multicast) over internal network (General Discussion)
by moore.tech 3/9/2017 9:44:58 PM(UTC)
RTSP Source : error 461 : Not a multicast request (General Discussion)
by akief 1/25/2017 8:22:24 AM(UTC)
Multicast/UDP/FFMPEG (General Discussion)
Belarus kjones9999 11/8/2016 12:21:32 AM(UTC)
Multicast UDP Transport Streams (Feature Requests)
by stevespaw 9/9/2016 9:43:18 AM(UTC)
Vmix multicast acquisition (General Discussion)
by macgiver76 12/19/2015 12:24:35 PM(UTC)
Multicast for "SDI must DIE" (Feature Requests)
by ethtv 8/20/2014 12:20:44 AM(UTC)
multicast (General Discussion)
by cambysys 9/3/2013 8:07:17 AM(UTC)
