Jacky
#1 Posted : Wednesday, October 2, 2013 7:41:30 AM(UTC)
Jacky
Dear all,
I`m a new member from Taiwan in this forums.
I`vn used vMix few days,
It`s amazing sofeware that I`ve used.
I got a think of a way to do is I use different channl like S-Video, Av, HDMI on my capture device in the same time.
(In other words, I can get three source in one video capture device)
is that available on vMix?
thanks all
Jup
#2 Posted : Tuesday, October 8, 2013 4:16:16 AM(UTC)
Jup
Hi Jacky, I'm new here too.
I would suggest you contact the manufacturer of your capture device for that answer.
I recently emailed StarTech asking if it was possible to record HDMI video and RCA Audio from their USB2HDCAP simultaneously.
They said it was only possible if using the composite video input, but not possible with the HDMI.
The manufacturer of your capture device ought to be able to tell you what it is capable of.
