	XML Data Sources Help (Newbie)
  Thanks: 8 times Was thanked: 7 time(s) in 5 post(s)
                I guess XML is easier than I thought. I found a example XML file with data and that went in fine. The XML file I tried to use with the sports league looked completely different. It has an XML extension but had totally different code. After seeing examples of XML it's a bit clearer.
  This topic can be deleted.
