Combine Local and Remote Commands iin Script
You have been a member since:: 3/7/2017(UTC) Posts: 60
Thanks: 3 times Was thanked: 6 time(s) in 6 post(s)
In my set up I have one PC that is solely for producing the actual show, and a second PC that streams the show. And for a while now I've been using the bulk shortcuts example as a way to automate cutting between a stand by image and the live show input on the streaming PC and to start recording. But now I'm looking for a way to create a script that automates triggers/functions for both the local and streaming PC. Here is an example: Cut to input 1 on streaming PC Start recording on streaming PC Start recording on local PC Turn on audio for input 1 on local PC Is there a way to create a script that sends commands to both my local PC and a streaming PC?
Thanks. But this is already what I do. I'm looking for a way to create a script that combines triggering actions on a local PC, and another vMix PC without having to write one script for controlling the 2nd PC and then creating triggers for the local PC.
