grDancer
#1 Posted : Saturday, January 13, 2018 8:58:28 AM(UTC)
grDancer
I don't know if I've changed a setting somewhere, but now whenever I add a camera input from my Intensity Pro card, there are two images stretched over the screen thus:
Any ideas how to fix this?
grDancer
#2 Posted : Saturday, January 13, 2018 9:05:34 AM(UTC)
grDancer
FYI it's not the camera - I tried it with another camera on the same HDMI cable/card and the same thing happened.
It's not happening on my other input cards - they're all showing up normally.
It only started happening after I updated VMIX a couple days ago, but have been tinkering a lot so I might have accidentally changed something.
It doesn't happen when I use the Blackmagic software to review the camera signal - it shows normally. It's only in vmix.
Could it be something to do with resolutions/aspect ratios?
grDancer
#3 Posted : Saturday, January 13, 2018 9:47:54 AM(UTC)
grDancer
Also - I noted that in saved vmix setups, the camera loads fine, but if I change the camera input (that input>settings>general>change) and select the same camera input, when it comes back, it's doing the dual screen thing. Weird.
spencerm24
#4 Posted : Saturday, January 13, 2018 10:21:01 AM(UTC)
spencerm24
Thats indicative of a progressive and interlace signal mismatch. Check your input and make sure its correct resolution, thats almost always a p/i mismatch.
thanks 1 user thanked spencerm24 for this useful post.
grDancer on 1/13/2018(UTC)
grDancer
#5 Posted : Saturday, January 13, 2018 10:54:35 AM(UTC)
grDancer
Thanks for the reply - where should I check/adjust this setting? Within a menu in vmix?
