Sometimes we have a production with more than 8 sources that need to be monitored, typically I like to have Program (output) and Preview as the two big monitors on top, and the 8 smaller ones below for sources. It would be nice to have a second multiview for fullscreen output for the sources that go beyond 8 (I know it has the 4x4 small window option but that isnt as useful to me as the two big ones on the top) A second multiview I could put 16 more sources on, and still have my large PGM/PVW monitors on the first multiview.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
Could you make another multi-viewer using the 10 layers available on each input? No tallies or level indicators but you could label them using a graphic on the top layer.
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
Peter B wrote:Could you make another multi-viewer using the 10 layers available on each input? No tallies or level indicators but you could label them using a graphic on the top layer. That would work as a good temporary solution, still a feature I'd like to see implemented for this use, would allow tally and audio which is important.
+1 I would love more multiview windows to see more inputs while switching live!
Joined: 8/16/2017(UTC) Posts: 25 Location: Lafayette IN
Was thanked: 8 time(s) in 3 post(s)
+1, it would be nice to be able to have more than 1 multiview with the ability to program hotkeys (or other shortcuts) to switch between them, or to show them on multiple screens
