Hardware Compatibility
Terratec G3 & G5 (grabster AV450 MX) USB video capture
I have been using Terratec G3 as a video capture device many times and it works fine on both Win 7 SP1 and Win 8. I have tested Terratec G5 (Grabster AV 450 MX) and can't make it work with vMix Anyone did ? Thanks
Joined: 9/11/2013(UTC) Posts: 10  Location: Calgary Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi gmaniglier,
Ask the manufacturer if this card does not compress the video. The vMix is compatible with cards that provide a raw video.
I hope it helps!
Cheers, Alexandre
