Would it be possible to add a Camera ID to AddInput&Input=1&value=Capture|DevID#|Resolution The ID would likely be how windows organizes the camera devices
How might I determine the GUID of a input before/while adding that input?
In addition to the Topic, I would greatly appreciate if we could add/modify/remove vMix desktop capture inputs using the API.
