cjpaul99
#1 Posted : Tuesday, January 2, 2018 2:00:17 PM(UTC)
cjpaul99
I have a BMD 4 SDI input/output DUO and a Nvideo Quadro M4000 GFX caRD. When I set Vmix to record externally on a Samurai Blade the video is perfect. The audio has a hit every 5 seconds or so. I also tried to perform a straight "Record" to an external raid drive in ProRes or H.264. Video is perfect, I get no audio. The "Record" audio meters are bouncing when I record so it should be there. Audio is set to record "Master".
Thanks,
Chris
