SetVolumeChannelMixer Shortcut
Joined: 4/22/2016(UTC) Posts: 83   Location: UK Thanks: 17 times Was thanked: 17 time(s) in 14 post(s)
Hi
I'm trying to use the faders on the APC mini to set the sub channel levels on a single input. I tried using SetVolumeChannelMixer shortcut, but I'm not able to specify which channel to modify in the shortcut dialogue - there is no entry box for it.
Did a quick test with SetVolumeChannel1, which works fine (with input set to 'Separate Mono').
G.
And, two years later, we continue with this problem. Submix's fader cannot be specified in the shortcut
Please, fix it!
