When vMix is used on intel XEON processor, it terminates abnormally without displaying an error message considerably frequently. Does vMix formally correspond to XEON?
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
Hello, what is the exact processor model/sku number?
I have had vMix running on Xeon CPUs for over 5 years. Something else is going on here. I suggest that you submit a support request to vMIx and if you can get the program up for a while, send a logfile by going to the Settings/About screen then click on "Send Support Request"
I don't believe it is a processor problem. I have been using vMix with an HP tower with twin Xeon processors for more than 2 years - never missed a beat.
Look in the event viewer if you can see what happens in the logs. Should be right there.
pba wrote:Hello, what is the exact processor model/sku number? Xeon E5-1650 v3 3.5GHz
Mathijs wrote:Look in the event viewer if you can see what happens in the logs. Should be right there. nothings listed.
clair wrote:When vMix is used on intel XEON processor, it terminates abnormally without displaying an error message considerably frequently. Does vMix formally correspond to XEON? I've been running a Xeon x5680 for a couple years now without issues with vMix.
Hello, this is not a processor related problem, I'm sure about this. We have a lot of LGA2011-3 based configuration, and these are rock stable units. clair wrote:pba wrote:Hello, what is the exact processor model/sku number? Xeon E5-1650 v3 3.5GHz
