YouTube 60fps in 50fps PAL country
Thanks: 192 times Was thanked: 20 time(s) in 17 post(s)
Dear all, my main cam goes up to 50 fps. This leads to these questions: - should I / should I not check the box '60 fps' for a YT Livestream event? - should I keep my overall vMix-setting at 50fps, or increase up to 60fps, if that would be the framerate that YT prefers? Since i stream mostly sports, 50/60 is preferred over 25/30. Please see the YT info at https://support.google.com/youtube/answer/2853702?hl=enThanks ! Arie
Arie, stick to your camera resolution and framerate as much as possible. YT handles 50 fps fine.
 1 user thanked ask for this useful post.
Thanks: 21 times Was thanked: 11 time(s) in 9 post(s)
Originally Posted by: ask  Arie, stick to your camera resolution and framerate as much as possible. YT handles 50 fps fine.
Not with Live it does't. Only VOD is encoded correctly.
