Renato_SBC
#1 Posted : Tuesday, December 12, 2017 4:29:36 PM(UTC)
Renato_SBC
Hi !
I´m trying to use this .bat to start VMix and StartStream:
Code:
timeout -T 30 /nobreak
start "C:\Program Files (x86)\vMix\vMix64.exe" "C:\Users\SSERVER\Documents\start_vmix.vmix"
timeout -T 20 /nobreak
Powershell.exe -ExecutionPolicy Bypass -Command "Invoke-WebRequest http://127.0.0.1:8088/api/?Function=StartStreaming"
:loop
goto loop
- First it´s make a 30 sec. delay after Windows start. It´s sufficient time on my machine to load all drivers and services.
- Start VMix by loading a preset
- Make a 20 sec. delay to VMix start
- Start streaming by web API
and now...
This machine works without monitor. It´s only capture two images, make a imposition and send the final image to two stream servers.
Some time my network (switch, router and modem) take much time to start and stream not start because a network error (a error VMIx error window is showed) and subsequent StartStream API commands is ignored until someone use a RAdmin or TeamViewer and click on 'close' button.
Has a manner to auto-close or no-show the error window when Stream fails to initiate, or use StartStream API command even with this error window open?
