nillemannen
#1 Posted : Tuesday, August 20, 2013 9:17:05 AM(UTC)
nillemannen
Am I doing it wrong?
I have a textfile (c:\names\nametitle.txt) which I write to with a 3rd party app.
I make a Flash / Rtmp input with my .swf which loads that textfile (c:\names\nametitle.txt) to two dynamic textfields.
Works perfectly, the name and title is clear and crisp.
BUT, if i change the contents my textfile (c:\names\nametitle.txt) the conten that I had to start with is still there, thus making the newly loaded content to appear superimposed over the old content.
If I "reset" the Flash input it retuns only with the new content, but it has been removed from multiview, where is where I use it.
Is there some caching involved, that keeps the old text?
Hope I make sense.
(I used this technique in xsplit, and it works there)
nillemannen
#2 Posted : Tuesday, August 20, 2013 11:33:15 AM(UTC)
nillemannen
Answering to myself:
Since vmix does not reload the swf, it just restarts it from frame one, one will have to clear all parameters on frame one and do the loading on frame two, then it works like a charm!
