Digisaurier
#1 Posted : Sunday, December 3, 2017 5:48:16 AM(UTC)
Digisaurier
Hi, perhaps this is a question some others users also are interested in: is there a way to bring the content that vMix Social is delivering in more than one title-input in a show? The idea behind: sometimes I want to show my viewers a comment or a question in a show as fullscreen, to make it better readable to them. Sometimes only as lower third. That means: two inputs using the same vmix social content stream. But in vmix social I can only set one Input to send the content to, as far as I know.
The only workaround I had was to use the lower3d Version, put it on a grey background and make it bigger via the zoom function. Not so elegant... So: any Ideas or solutions to that?
thx a lot
ChriS
Digisaurier attached the following image(s):
