determining whether an input is active
Joined: 8/4/2012(UTC) Posts: 129 Location: the Netherlands
hi,
i am writing up a small program for my remote control box that will be mounted on my mobile camera (i am director, cameraman and mixer in one) and will show which cameras(inputs) are active. Thing is i use a lot of multiviews on inputs to do pip etc. How can i see whether an input is active when it's used as a multiview overlay, cause if my experiments are correct it won't show up as either the active or the overlay items in the 'result-xml'
if need be i can configure my program to be aware which cameras are used in which multiviews, but that takes a bit of flexibility.
Is there something i'm overlooking, if not can i request it as a future (i think it's not really hard to program)
regards.
M@ik
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
This is not currently possible, but thanks for the feature request which I will keep in mind.
Martin vMix
if that would be easier i would be happy to do some interpreting myself so a list of used resources in a multiview either in the 'status' xml or in a seperate call would solve my issue as well
like api?cmd=getresources&id=unid or something
M@ik
