rockchalkjayhawks
#1 Posted : 7 years ago
rockchalkjayhawks
Does anyone else have this problem?
If I have Instant Replay in any reverse play mode (play, search, shuttle).
Then pause playback.
Then select several events for playback and play those events. Instant Replay plays the first frame of selected event and then goes back to pause mode.
This is a common work flow when using Instant Replay in a live sports production as a replay system.
If Instant Replay's last function is forward play mode, then pause, then select events and play them...it works flawless.
Any idea what is causing this? Is it a software glitch that needs to be changed so that play back of events is always in forward mode at a 100%?
