michaelrb
#1 Posted : Monday, November 13, 2017 2:53:12 PM(UTC)
michaelrb
I believe I have set up NDI properly, however, the instructional video says I should change Skype settings as follows: 1)Audio set to virtual cable 2)video set to vmix video. This setting does not appear as an option. I am using the full version of SKYPE on Win 10 surface pro. Any suggestions? Also, not sure about external output settings. Are they set on the Main Vmix PC, or on the Skype PC or both?
Do you set regular external outputs, or NDI outputs?
AlanZ
#2 Posted : Thursday, November 16, 2017 1:29:58 AM(UTC)
AlanZ
Are you running the windows 10 skype app, or skype classic? I don't see vMix as a choice in the app, but it works fine in classic.
