Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
It would be really useful if you could postion overlays and muliview items in exact postions on the output. I know you can change the output size which would then relativley change the pixel postions of these items.
For example i have an LED wall 2048x640 and another two walls that are 960x720
They all 'exist' on a single 4K canvas - in this case i can set one display to be the big wall and the other to be 1920x720 (the other two walls are right next to each other in the pixel space!)
I apreacate vMix is not really the tool for what i am doing and really i should be using Arkaos or similar however i know and love vMix and own a licence! I don't know nor own a licence for Arkaos!
As an asside i offten have the followinf situation and wondered what is actually happening internally in vMix and what effect it may have on the quality of the play back.
Client provides a pixel perfect video say 1920x640. I setup an HD vMix show I set the output of display 1 to be 1920x640 I choose an aspect ratio for the input video (normally wide screen or scoure) that makes it fit the playback window.
I assume there is a bunch of up scaling and then down scaling going on thought the internals of vMix?
