arlind
#1 Posted : Thursday, November 2, 2017 1:06:05 AM(UTC)
arlind
hi, i have a mp4 video and i converted it to image sequences (i can inport in vmix via image sequence and it will play same as video)
so i want to add those images in BLEND then to add some text that can be changed later from vmix.
all is ok but when i play in BLEND it goes same as video and when i play in vMIX it goes same as example 10 FPS (its not fluid)
Code:
<UserControl x:Class="NAME"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:mtl="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
Width="1920" Height="1080">
	<UserControl.Resources>
		<Storyboard x:Key="Storyboard1">
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image">
				<DiscreteObjectKeyFrame KeyTime="0" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.03" Value="{x:Static Visibility.Hidden}"/>
			</ObjectAnimationUsingKeyFrames>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image1">
				<DiscreteObjectKeyFrame KeyTime="0" Value="{x:Static Visibility.Hidden}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.03" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.06" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image2">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.06" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.09" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image3">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.09" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.12" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image4">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.12" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.15" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image5">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.15" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.18" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image6">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.18" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.21" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image7">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.21" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.24" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image8">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.24" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.27" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image9">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.27" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.30" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image10">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.30" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.33" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image11">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.33" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.36" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image12">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.36" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.39" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image13">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.39" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.42" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image14">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.42" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.45" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image15">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.45" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.48" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image16">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.48" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.51" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image17">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.51" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.54" Value="{x:Static Visibility.Hidden}"/>
			<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="image18">
				<DiscreteObjectKeyFrame KeyTime="0:0:0.54" Value="{x:Static Visibility.Visible}"/>
				<DiscreteObjectKeyFrame KeyTime="0:0:0.57" Value="{x:Static Visibility.Hidden}"/>
				<ObjectAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.Visibility)" Storyboard.TargetName="TITLE">
					<DiscreteObjectKeyFrame KeyTime="0:0:0.8" Value="{x:Static Visibility.Visible}"/>
		</Storyboard>
	</UserControl.Resources>
	<UserControl.Triggers>
		<EventTrigger RoutedEvent="FrameworkElement.Loaded">
			<BeginStoryboard Storyboard="{StaticResource Storyboard1}"/>
		</EventTrigger>
	</UserControl.Triggers>
 <Grid x:Name="LayoutRoot">
<Image x:Name="image" Margin="0,0,0,0" Source="img_001.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image1" Margin="0,0,0,0" Source="img_002.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image2" Margin="0,0,0,0" Source="img_003.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image3" Margin="0,0,0,0" Source="img_004.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image4" Margin="0,0,0,0" Source="img_005.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image5" Margin="0,0,0,0" Source="img_006.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image6" Margin="0,0,0,0" Source="img_007.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image7" Margin="0,0,0,0" Source="img_008.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image8" Margin="0,0,0,0" Source="img_019.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image9" Margin="0,0,0,0" Source="img_010.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image10" Margin="0,0,0,0" Source="img_011.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image11" Margin="0,0,0,0" Source="img_012.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image12" Margin="0,0,0,0" Source="img_013.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image13" Margin="0,0,0,0" Source="img_014.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image14" Margin="0,0,0,0" Source="img_015.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image15" Margin="0,0,0,0" Source="img_016.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image16" Margin="0,0,0,0" Source="img_017.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image17" Margin="0,0,0,0" Source="img_018.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<Image x:Name="image18" Margin="0,0,0,0" Source="img_029.png" Stretch="Fill" InputMethod.IsInputMethodEnabled="False"/>
<mtl:TextBlockDesign x:Name="TITLE" Text="Test TiTLE HERE" Margin="130,822.401,-130,202.401" Fill="White"/>
  </Grid>
  </UserControl>
