EdMediaServices
#1 Posted : Saturday, October 28, 2017 12:21:44 PM(UTC)
EdMediaServices
For your scoreboards, can you please add increment tabs, i.e. +1, +2, +3 for each scoreboard. This would allow for easier and faster scoreboard changes rather than having to type in the new score each time a goal is scored. For faster-paces sports such as basketball, this allows a single operator to make the change and move on to other duties quickly and it also creates a more accurate solution to possibly creating a typo when entering a score manually.
Thanks for your consideration.
Pete Stover
EdMediaServices
MartLeib
#2 Posted : Saturday, October 28, 2017 12:53:50 PM(UTC)
MartLeib
Estonia
Hi Pete!
You can use shortcuts for that. Command you are looking for is SetText with values +=1 +=2 +=3
SportsNetUSA.net
#3 Posted : Saturday, October 28, 2017 12:55:25 PM(UTC)
SportsNetUSA.net
MartLeib types much faster than I can :)
Stef
#4 Posted : Friday, November 10, 2017 10:18:15 AM(UTC)
Stef
Selected font sizes for scoreboard and lower thids.
