jordi.palou
#1 Posted : Thursday, October 26, 2017 1:48:56 PM(UTC)
jordi.palou
Is there any Vmix compatible PTZ Camera (please indicate manufacturer and model) which can memorize focus setting for any position preset?
Thank you very much!!!
Cpilcher
#2 Posted : Thursday, October 26, 2017 3:46:28 PM(UTC)
Cpilcher
You can create custom position presets with any vMix compatible PTZ I believe. I have a camera that is not compatible unfortunately (AXIS v5915). But from what I have read, you can move the PTZ to a preset location and create an input based on that location. You can then click that Input to change to that position as if it were multiple cameras brought into vMix.
CPilcher
