Error when using multiple instances of vMix Social
Joined: 10/8/2013(UTC) Posts: 45  Thanks: 4 times Was thanked: 6 time(s) in 5 post(s)
Hello, we keep getting the attached error. We are using three instances of vMix Social to track posts on Instagram & Twitter (with pictures & without in two seperate instances). As the error is german I try to translate it as good as possible: Unhandled exception in the application. Click CONTINUE to ignore the error and continue the application. If you click QUIT the app will be closed immediately. The config file was changed by another program already. PATHThis error comes up unregularly and we keep clicking CONTINUE of course. vMix Social keeps working fine all the time, no matter how oftne the error occurs. But the error of course is annoying and we try to get rid of it. Does anyone know a solution? Cheers, Daniel DeeJay attached the following image(s):  Fehler.jpg (147kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
