Feature Requests
Sync two or multiple VMIX
Thanks: 3 times Was thanked: 2 time(s) in 2 post(s)
Hello guys,
I would like to suggest that you could enable in some simple way the possibility to control one vmix and that he replicates all the actions to a "slave" machine running vmix. Hardware should be similar, of course. Redundancy is something that i use a lot of times. normally i use mouse without borders to control all the machines and replicate this effect, but something more oficial trough scripting i guess would be better.
Also i feel like the potential in the API is very strong but for someone who is not a developer but understands a few concepts is not easy. I guess documentation could be more helpful on giving practical examples.
Thank you and keep up the good work.
 1 user thanked livestreaming for this useful post.
Joined: 4/22/2016(UTC) Posts: 83   Location: UK Thanks: 18 times Was thanked: 17 time(s) in 14 post(s)
Thanks: 27 times Was thanked: 19 time(s) in 16 post(s)
Hello "Livestreaming",
I just found your post because now I have the same challenge: running 2 vMix programs on 2 PCs simultanously with same NDI inputs. I know that you post is 3 years old, maybe you found a solutions during this time and would tell me?
Thanks a lot! Niko
Joined: 12/26/2020(UTC) Posts: 5  Location: Hamburg Was thanked: 5 time(s) in 1 post(s)
Have a look on "Companion", so with one Streamdeck (or without) you can control as many vMix instannces as you like :)
Rank:: Advanced Member
Feature Requests
