Yannick
#1 Posted : Thursday, October 12, 2017 3:47:00 AM(UTC)
Yannick
For Multicam setups the Shortcuts: SetOutputExterna2, SetOutputFullscreen, SetOutputFullscreen2 are a nice feature to cut different sources directly with a midi device to those different outputs.
However, this doesn´t offer the possibility to use transitions for those cuts.
It would be sufficient to add an additional parameter to the SetOutputxxx that allows to chose which transistion should be used for the shortcut.
thanks 1 user thanked Yannick for this useful post.
David_in_Philly on 3/22/2018(UTC)
