BETech
#1 Posted : Wednesday, October 11, 2017 5:48:08 AM(UTC)
BETech
Windows Update MiniTool is a free alternative to the standard Windows Update, it puts you in control of updates by allowing you to search, install and block Windows updates as you please.
A great tool for mission critical systems such as vMix on Windows 10.
Windows Update MiniTool will provide the following options:
Check for updates
Download updates
Installing Updates
Deleting installed updates
Hiding unwanted updates (such as unnecessary drivers, service packs, new Windows pre-release builds)
Get direct links to the *.cab / *.Exe / *.Psf update files
View update history
Balloon Helpers & HTML links, explaining the nature of the Update
Configure Automatic Updates :
Automatically - Updates are checked, downloaded and installed automatically.
Disabled - Updates are not checked, not downloaded, not installed. Updates performed manually.
Notification mode - Notify before downloading and installing any updates.
Download only - Download the updates automatically and notify when they are ready to be installed.
Scheduled - Automatically download updates and install them according to schedule.
Managed by Administrator - Local admins control Automatic Updates mode.
Your choice to take control.
Download link 1 : Includes video demonstration
http://www.majorgeeks.co...ows_update_minitool.html
Download link 2 : Includes change log
https://wumt.blogspot.com.au/
