snabela86
#1 Posted : Monday, October 9, 2017 3:22:31 PM(UTC)
snabela86
Hi!
I have tried to change the url in a browser input (by right clicking and then properties I think) and then save, but it doesn't seem to be saved. When I restart vMix the old url for the input is back. Can I change the saved url somewhere else or is the only option to delete the input and create a new one?
Johan
sinc747
#2 Posted : Monday, October 9, 2017 3:32:10 PM(UTC)
sinc747
I can confirm this report.
However, to change a Web Browser Input, go to the settings for that Input, select the General tab in the left column, select the Change button (top right) and add the new URL there. Save the Preset and the next time you use that Preset, it will load your new URL in that Input.
Good luck!
- Tom
snabela86
#3 Posted : Monday, October 9, 2017 4:49:40 PM(UTC)
snabela86
Thank you! It worked and I wonder why I didn't think of this before, but know I know!
Johan
