Instant Replay
Shortcut command to change the selected angle
Joined: 3/19/2017(UTC) Posts: 15 Location: Canary islands, ES
Hi!
I'm trying to test some external commands to improve our replay workflow and not be so dependent on mouse and keyboard, but i'm finding some difficulties.
The system allows changing the text (tagging) of each camera, but that it's not possible at all with the Shortcuts. We are either missing a "Camera" parameter on the ReplaySetLastEventText/ReplaySetSelectedEventText commands to do it directly, or a ReplaySetSelectedAngle command (to mimic the mouse way to do it).
Is there a workaround for this or will i be limited to tagging the first input only?
Instant Replay
