stigaard
#1 Posted : Friday, September 29, 2017 4:44:46 AM(UTC)
stigaard
Denmark
Hi vMixers,
In earlier versions it were possible to adjust the width of the columns in the replay module, but presently it is not possible. I wish to see it possible to adjust the column widths of the four input camera angles - the first few columns is fine by being fixed, but for the angles are important to have adjustable.
Best regards
Jens Stigaard
#2 Posted : Friday, September 29, 2017 5:02:44 AM(UTC)
+1
dmwkr
#3 Posted : Friday, July 16, 2021 2:48:18 AM(UTC)
dmwkr
This is still (or again?) happening to me in 24.0.0.63, and on a 2nd machine with 24.0.0.56. (FWIW, on a backup laptop running 23.0.0.65 it IS possible to resize the column width, though sometimes there suddenly appears another column while resizing, as if you have another camera.)
Is this a coincidence, that it's happening on two machines? Can anyone confirm this bug?
Currently, it is only possible to see approx. 19 characters of the event text, and in this case we need waaaaaaaay more to quickly find events... :)
Law265
#4 Posted : Saturday, August 14, 2021 6:53:42 PM(UTC)
Law265
American Samoa
The option to change the properties of the columns are greyed out. For all columns. enter image description here. Share.
parts login portal
Zeigler5
#5 Posted : Thursday, October 7, 2021 3:32:15 PM(UTC)
Zeigler5
Germany
since last update in hosted I am unable to change columns width or resize windows?? Transaction are blurred. Using Chrome.
dinar guru
