vMix Call
vmix call on iOS 11
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
I just tried vMixCall.com on iOS 11 on two devices
On an iPad Mini 2, the call connected fine, I could see the vMix output and vmix could see the ipad's camera However after a few moments, the 'toolbar' disappeared and I could not find a way to bring it back except for refreshing the screen... and then it stayed only for another couple of moments.
On an iPhone 6, vmix could see the phone's camera, but the phone could not see the vMix output at all (the phone's camera and a blue screen is all I was able to see on the phone). I tried this with safari... then with Chrome. Chrome did not show the camera nor the vmix output.
So... we're getting closer, but there is still a way to go.
Joined: 6/6/2016(UTC) Posts: 19   Location: The Netherlands
Yes, I have the same problem with my iPhone 6S Plus.
vMix does receive the iPhone video, but it doesn’t send video back. I do hear the audio feedback. At first I did not see myself on the iPhone screen, but then I touched the PIP screen and the toolbar appeared. Then just tick on full-screen and there you are. No need to refresh. But still no video feedback.
It would also be nice te have the option to switch camera front to back during the connection and maybe even choose which iPhone microphone to use.
I can work with this, but it does need a little love.
woohoo finally!
It works well!
It just needs some fine tuning on the position of the elements (buttons etc) but i'm happy :)
mashynewie2 wrote:It just needs some fine tuning on the position of the elements (buttons etc) but i'm happy :) How about that you provide your suggestions to the fine tuning? E.g. including a screenshot of the current screen, and how you want it to look? :-) Then it is easier for the developer to take into considerations.
I just did a test with 20.0.0.30 on my iPhone 6 with Safari browser and it worked very very well.
No issues at all seeing/hearing audio/video, and was able to get to the popup controls.
A very nice step forward!
Chrome on the iPhone 6 did not work at all. It does not display the camera selector, and when I join I get no video from the host, and no video on my phone.
Thanks: 16 times Was thanked: 11 time(s) in 9 post(s)
Just did some tests with an ipad Air 2- seemed to work fine, but on an iPhone 7, the phone went black after a few seconds and froze up, not buttons working - call audio still coming through, but the phone effectively totally unresponsive.
Did you try changing orientation of the iphone or iPad once the call started. On my iPhone 6 it is locking up when I change orientation. However, I'm running 11.1 Beta so trying to figure out if it's a new problem or not.
On a side note, I have tried to use vMixCall on Safari on a MacBook. Seems to work great except for one issue in that I can't change devices. I have a Magewell USB plugged in and this works fine with FaceTime, Chrome etc but in Safari, there does not seem to be a button to change sources.
Am I missing something or is this feature not there yet?
vMix Call
vmix call on iOS 11
