1. The ability to see the length of your selected events before you play them.
2. Please change or give the user the ability to change the color of the selected event in the event list screen. The orange color makes it difficult to see which angle(s) are selected. The orange "selected event" bar and the red "angle select" box are very difficult to differentiate.
3. For us "JKL" editors, the ability to have true J & L speed control would be awesome. Meaning...with each successive push of the L key the speed of forward playback increases by a certain increment (1x, 2x, 10x, 30x, etc). And of course, the same applies to the J key except it is reverse playback.
