ccolewilliam
#1 Posted : Sunday, September 17, 2017 10:08:52 AM(UTC)
ccolewilliam
I am trying to figure out if there is a way to crop an overlay. For example if I have a lower 3rd that lifts up as a "vertical swipe". Is there a way I can crop out where it lifts vertically from. So it doesn't move across the entire screen Just lifts from where my graphics are at?
element
#2 Posted : Sunday, September 17, 2017 4:39:10 PM(UTC)
element
Hey, each overlay had a normal mode and then already a Picture in Picture mode, you should be able to use the PiP mode to do what you are looking to do.
Alternatively you could turn your lower third into a quick animated AVI with the animation already in place.
