Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
Is there a way to convert rs 422 to ip and then convert back to rs422 to connect to a PTZ controller?
alexandrelinhares1 wrote:Hi,
Is there a way to convert rs 422 to ip and then convert back to rs422 to connect to a PTZ controller? Do you want to use Network cables or control the cameras with an IP controler?
xaver wrote:alexandrelinhares1 wrote:Hi,
Is there a way to convert rs 422 to ip and then convert back to rs422 to connect to a PTZ controller? Do you want to use Network cables or control the cameras with an IP controler? I want to be able to convert the serial signal to IP so I can put it on a network and then pick it up somewhre in the network and convert it back to serial.
